IES Lights in Mental Ray
Dave Buckley
Does anyone have any best practices or tips for lighting a scene with a daylight system and IES lights, (for example, a night time interior). I can put IES files into my scene but everything is really dark. Even when i'm not using the daylight system.
My first test was a living room scene, with a series of IES lights in, logarithmic exposure and GI turned on in Mental Ray, Max 2008 by the way.
The scene appeared really dark and not very realistic.
My method for putting in the IES lights was to first create a series of target point lights and then change the distribution to WEB and then laod the ERCO file that i had downloaded.
Am i doing things right, or where am i going wrong???
If i want to be lighting an interior with IES lights then what methodology should i be following, because it would appear i'm misunderstanding a few things.
Thanks for any help (this is pretty urgent)
exposure control, exposure control,exposure control, its your friend, use it
as long as you have put in realistic values for the ies lights and the model is to a real world scale, then they work great. Use exposre control to brighten your scene rather than upping the lights values
Here I have a 3mX5m room. MRsun and Sky, portal light in the opening and a photometric light, All default values.
See the difference a bit of exposure control makes.
jhv
  • 2 weeks later...
  • 1 month later...
