vray sun question..
shikodesign2000
sun intensity outgh to be no more then 0.003 or even less, with either standard or vray physical cam.
unless, in vray physical cam, you change the shooter time as stef mentioned or change the vray setting to a lower luminosity values.
if you are not very familiar with vray setting luminosity, I would go for the sun intensity to 0.002. ligther floor colours would certainly look much brighter then the dark ones.
This is kind of a "band-aid" approach, but in combination with lowering the light intensity; a lot of times I will adjust the refractive value of the glass the light is coming through so it doesn't let as much light in.
I've definitely had the same problem though so you're not alone.
M-
