fernando-1 Posted December 10, 2003 Share Posted December 10, 2003 Can I import lightscape 3.2 materials when I import my LP or LS file into Viz? For some reason I only seem to import lights and objects with no materials. If so how. Thanks Link to comment Share on other sites More sharing options...
William Alexander Posted December 12, 2003 Share Posted December 12, 2003 fernando-1, They should still be there. Just not in the material editor. In viz3 for example, you save the max file before exporting to lp. Run your solution and import it back into the unchanged max scene. You can open and close it, but do not re-save the file. In the material library browser, click design or scene. This should bring up the materials stored/ applied to the objects. Drag into the material editor and when prompted select instance. If this is not it, then there is something going on with the import lightscape dialog set up. Hope it helps WDA Link to comment Share on other sites More sharing options...
