jace Posted December 24, 2007 Share Posted December 24, 2007 Hi everyone, This is my first post; just discovered CGArchitects recently. Great resource. I have a question. I've been starting 3ds max 9, and attempting a boolean union on two closed splines, to heal the joint between the two walls, as shown in the pic. I constantly get the error “ERROR: Final boolean weld stage failed”. What does this really mean, and can anybody suggest a workaround to this? Other fora suggest increasing the number of vertices, reserving vertices, or applying the edit spline modifier, but nothing like it works. Link to comment Share on other sites More sharing options...
Horhe Posted December 24, 2007 Share Posted December 24, 2007 Cant you just trim the intersecting parts of the spline and weld the verticies? Link to comment Share on other sites More sharing options...
Lester_Masterson Posted December 24, 2007 Share Posted December 24, 2007 With the amount of time you have spent trying these alternate methods, you could have redrawn this (traced over it) as a single entity about 30 times. Link to comment Share on other sites More sharing options...
jace Posted December 24, 2007 Author Share Posted December 24, 2007 True. There are easier ways to do this. I'm working through Autodesk Viz 2007 by Omura, Onstott and McFarland. I've tried the same thing in Viz, but the result is the same as in 3ds Max. The point is, even though I'm following the instructions to the letter, I can't get the result from the book. And yeah there are basic alternatives to doing this, I'm simply trying to find out what I could've done wrong, and learn a lil more about the program. Link to comment Share on other sites More sharing options...
