@lkion O Posted January 30, 2003 Share Posted January 30, 2003 Hello everyone i finaly managed to use hdri shop with viz 4 - with your help of course. This is my first image, its been compressed down, but i think the result are good! http://www.cgarchitect.com/forum/filepush.asp?file=hdr.jpg Here is another question for all the viz users. In order to use hdr i need to set it as you suggest as environment map and then as skylight. But what if i want to use the light coming from the hdr but i want to have another backround - so i can use camera match technique. Is there any way i can do this? Thank you all Link to comment Share on other sites More sharing options...
plastic Posted January 30, 2003 Share Posted January 30, 2003 how did you render that? i don't know the maps you used, but that doesn't look right to me. for different environment & background there are multiple ways. brazil and vray can load their own skylight maps. or you can use a skydome (geosphere with flipped normals and hemisphere) which is invisible to the camera (object properties). Link to comment Share on other sites More sharing options...
Christopher Nichols Posted January 30, 2003 Share Posted January 30, 2003 This is what I would try: - Use a skylight in Viz 5. - In the skylight settings use a map - Make sure the "Map" checkbox is checked - use a bitmap, and select the hdri image - open the material editor - drag the bitmap from the skylight to an empty spot in the material etidor - a dialogue will come up to copy the map... select "instance' - on the bitmap options, select "Environment" (instead of "Texture"). - Under the Mapping type, select "Spherical" That should work. Now you can have a different environment which will be different from your light. Link to comment Share on other sites More sharing options...
@lkion O Posted January 30, 2003 Author Share Posted January 30, 2003 Thanks Cristopher and Plastic that seems to be workin!!! Plastic really liked your plug in page!!!When do you think you will upload those manuals? Link to comment Share on other sites More sharing options...
plastic Posted January 30, 2003 Share Posted January 30, 2003 ahh, the manuals... i'll try to complete them in the following weeks. i'm glad you liked the page. Link to comment Share on other sites More sharing options...
@lkion O Posted January 30, 2003 Author Share Posted January 30, 2003 ok thats sounds great!!! Do you have any samples of your work which show their use? Link to comment Share on other sites More sharing options...
plastic Posted January 31, 2003 Share Posted January 31, 2003 samples...well, here are two recent projects where i used tree shop plants and neon lighting. more images here . Link to comment Share on other sites More sharing options...
