piotrgreg Posted December 26, 2007 Share Posted December 26, 2007 Hi everybody the problem is: I have recently upgraded my Viz to 2008 version as well as recent Vray I have a big problem with linking *dwg files from Acad - I can't reload my file without missing my materials definitions on reload - I have already studied viz help file ab reloading quite long , but it seems to me there's some other problem involved. Do anyone of You have faced same problem? Is ther any solution? I ll appreciate quick response Piotr Link to comment Share on other sites More sharing options...
colorID Posted December 26, 2007 Share Posted December 26, 2007 hi, u have to make a new preset that will have both "use scene material difintion " and " use material assignment on reload" turned on, then use that preset at the begining when u link your autocad file. without using that preset at the begining you cant keep the link in the right way. Link to comment Share on other sites More sharing options...
piotrgreg Posted December 26, 2007 Author Share Posted December 26, 2007 Mohammed, as I've mentioned, I have studied help file and, of course "Use Scene Material Definitions" and "Use Scene Material Assignments on Reload" functions are ON with the very first linking.... and there's still a problem any other idea? Piotr Link to comment Share on other sites More sharing options...
Ray Posted December 26, 2007 Share Posted December 26, 2007 http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9555503&linkID=9242899 Link to comment Share on other sites More sharing options...
