mental ray interior problem
alex222
Hello everybody.Can anybody hepl me
First of all a work in 3ds max 2008,and i have a problem iluminating a interior.
This interior don,t have windows,its all iluminated whit artificial light.
The render is very blurry and poor.
Theri atached images of the renders and the setings off the final gater and the lights .All the lights are instanced.
In the image named sala yoga the lights are area spot and in the other image are area omni
All the materials are arch and design materials
I don,t now what is making bad
the renders take apromitade 4 hours at 1500x700 pixels in a amd atlhon 64x2 dual 4800+ whit 2 gigas off ram.
The so is windows xp pro.
Thanks for your,s answers and sorry by my english.
You should certainly take it off the High setting, really nice looking results can be acheived on the draft setting.
In the AA settings, i use Min = 1 and Max = 16, and change the filter to mitchell. This is usually the last thing i do though as it will increase render time.
Are you using Global Illumination? I start with GI and then switch on Final Gather later to fine tune the image. Experiment with Number Of GI Photons per light, sampling radius and the number of Photons per sample within the Global Illumination rollout.
Also make sure you have got logarithmic exposure on in the environment rollout.
You need photons alright and just use a draft setting for FG it's enough to start with. Also you need to turn your photon emitter on in at least one of your lights and I usually use 10,000 in all the photon size settings although you might not need these that high either. Lets us know how you get on?
Tommy Burns - it will really help you to fully understand what each of the settings do. For example 10 000 average photons is fine for draft renderings but not of a detailed rendering, and a 10 000 max sampling radius will be too large of a 3mX3m room but too small for a football stadium.
JHV
sorry bout that just trying to help someone as I walked out the door hadn't time to go into much detail. I was just saying really what I would start with was 10,000 but I mainly do exteriors and yes your right I would sometimes use more or less for interiors. All I really wanted to say was "use photons with FG".:)
