chow choppe Posted January 3, 2008 Share Posted January 3, 2008 I am working on a quad core machine with a 512mb card Hd3870 While working in max9 in 64 bit windows if i work on a heavy scene max crashes and gives error if i use direct 3d as viewport configuration driver and i again try to open it it again crashes.If i change to openGL thefie works fine but then my vieport navigation is slow as compared to sirect 3d. How can i solve thiss issue because i ahve always heard that we should use direct 3d in 3dsmax. Also FYI i am using directx9.0c Thanks Link to comment Share on other sites More sharing options...
chow choppe Posted January 9, 2008 Author Share Posted January 9, 2008 no body knows? shud i use direct X or open GL? Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted January 10, 2008 Share Posted January 10, 2008 no body knows? shud i use direct X or open GL? If you have ATI card, maybe you can try w/OGL nV works perfect w/D3D, times changed! Link to comment Share on other sites More sharing options...
chow choppe Posted January 11, 2008 Author Share Posted January 11, 2008 yes i have ATI HD3870 512Mb DDR4 But if i use open GL the display gets slow and its faster in direct3d Link to comment Share on other sites More sharing options...
ebad Posted January 14, 2008 Share Posted January 14, 2008 wow! I was looking for a solution for my problem and I thought that this is my own problem! My Hardware is too different but I have same problem! CPU : AMD X2 Dual core 4400+ VGA card: nvidia Gfource 7300 And Windows xp x64 edtion also! I have found out a point, did you know? when I open the dxdiag and goto the 64bit version of dxdiag, I found that the version of directx is "not found" And I think there is some problems with installing dirrectx on this windows I think the dirrectx can not operate in 64bit mode, and it acts as well as in windows 32bit edition. please let me know about what you find about this problem. Link to comment Share on other sites More sharing options...
chow choppe Posted January 15, 2008 Author Share Posted January 15, 2008 i opened dxdiag and everything is fine Its shows me directX9.0c installed WE face dthe same peoblem with win32bit also So i think the reason is something else Thanks Link to comment Share on other sites More sharing options...
ebad Posted January 18, 2008 Share Posted January 18, 2008 Here I've attached some pictures showing the problem obviously, I hope they help, And some one helps us! Thanks. Link to comment Share on other sites More sharing options...
chow choppe Posted January 19, 2008 Author Share Posted January 19, 2008 same problem but its showing my direct x version as 9.0C in 64bit mode also Link to comment Share on other sites More sharing options...
jarggo Posted April 9, 2008 Share Posted April 9, 2008 I got the same problem. In my case it happens only when using Vray. And when "show map in viewport" used (read: always). Link to comment Share on other sites More sharing options...
sirr Posted March 10, 2009 Share Posted March 10, 2009 Has somebody found solution for this problem? Link to comment Share on other sites More sharing options...
sirr Posted March 10, 2009 Share Posted March 10, 2009 not the solution but an answer: http://area.autodesk.com/index.php/forums/viewthread/12612/ Link to comment Share on other sites More sharing options...
