Tim Saunders Posted January 5, 2008 Share Posted January 5, 2008 I have never had any luck installing the Maxtreme drivers. I finally wanted to get to the bottom of it. I have heard people raving about the performance enhancements by using this driver alone, but I have tried with 5 different releases of max, viz and maxtreme. Every attempt is a failure. I am running Max 2008 on Windows XP 32-bit. My Video card is Nvidia Quadro FX 3450 (I also have a 3400 on a second workstation). After installing the driver I get an error that an ini file was not found, but the driver was still installed. After switching the driver in Max, I exit and re-open max, but I get an error that says "Loading of custom driver failed. Forcing null driver mode." How can I make the driver work? I would really like to try it out. Link to comment Share on other sites More sharing options...
martincg Posted January 5, 2008 Share Posted January 5, 2008 Hello Timothy, do you have installed nvidia drivers for quadro too? http://www.nvidia.com/object/winxp_162.65.html i have fx 3450 with 32 bit max 9, 32 bit windows and no problem with that Link to comment Share on other sites More sharing options...
gfa2 Posted January 5, 2008 Share Posted January 5, 2008 I have the FX 4500 and I had all kinds of problems getting Maxtreme to work. I did finally get it work by upgrading my Windows video drivers (even though the guys at Boxx said not to do it), but even then it seemed flaky. I just stick with the Direct3D drivers. If you crank the settings up for them, I think it does just as good. Link to comment Share on other sites More sharing options...
Tim Saunders Posted January 7, 2008 Author Share Posted January 7, 2008 Yeah, I have the latest quadro driver. I have been running off Direct3D display forever. I just wanted to try out Maxtreme. Looks like the consensus is to forget about Maxtreme, and stick with Direct3D. Link to comment Share on other sites More sharing options...
gfa2 Posted January 7, 2008 Share Posted January 7, 2008 At the time that I experimented with this I was using max 8 and I found several versions of Maxtreme for max 8, and the one that ended up kind of working wasn't even the newest one. I got tired of wasting time on it. Link to comment Share on other sites More sharing options...
Tommy Burns Posted January 7, 2008 Share Posted January 7, 2008 I used it with max 9 and I never had a problem with it (quadro 4500) Now I have 2008 and I can't get a driver for it or else I haven't Installed it properly. Would love to use it again cos I never had any problems with it? Anyone using it with 2008 Link to comment Share on other sites More sharing options...
Matt McDonald Posted January 7, 2008 Share Posted January 7, 2008 there is a bug in the Nvidia installer for the maxtreme 2008 driver. it installs the 64 bit driver on 32 bit max installs and vice versa. just copy the maxtreme.drv file for your appropriate os into the root max install folder. Link to comment Share on other sites More sharing options...
iancamarillo Posted January 29, 2008 Share Posted January 29, 2008 in max 2008 using maxtreme, has anyone noticed objects shifting slightly when moving them in viewport? Link to comment Share on other sites More sharing options...
danb4026 Posted February 5, 2008 Share Posted February 5, 2008 Is there a Maxtreme 2008 for Vista 64bit yet? From most of what i hear, it doesnt seem to be worth installing anyway. Any advice? Link to comment Share on other sites More sharing options...
