VIZ Radiosity Interior/Exterior Animation
Eric
I'm curious to know how others handle an animation that moves from the exterior to the interior. I'm using photometric lighting on the interior (mainly Erco lights) and need to show sunlight on the exterior. When I add the daylight system it screws up the lighting levels inside. What method do I need to use to include exterior and interior lighting in one seamless animation?
in the past i have set up 2 files. one with ext lighting, and one with int lighting. i import the same camera path into both files, and render a overlap of about 100 frames. then in aftereffects i fade between the 2 as i go inside.
the results usually work ok. it usually looks like your eyes are adjusting for the change in light intensity.
