halt Posted January 6, 2008 Share Posted January 6, 2008 Does anyone know why vraysky is missing? (see attached image) I'm using 3dsMax 9 on a PC with vRay 1.5. Thanks! rockin'in08 Link to comment Share on other sites More sharing options...
manta Posted January 6, 2008 Share Posted January 6, 2008 actually its the vraysun that's missing...sorry don't know where it is...contact Chaos I guess... Link to comment Share on other sites More sharing options...
jorisAR Posted January 6, 2008 Share Posted January 6, 2008 I once had the same problem but then with 'vrayplane' but that was because I reinstalled 3DS max and not Vray, and since Vray is a plugin some things weren't reattached to max. I reinstallend Vray too after I reinstalled max and then the problem was fixed. Hope it helps to fix your problem too. greetz Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted January 6, 2008 Share Posted January 6, 2008 All VRay tools are actually separate plugins (.dlo, in this case). If they are not showing, it's probably because Max is unable to find or load them. Re-installing VRay should fix it. Link to comment Share on other sites More sharing options...
