Koper Posted January 7, 2008 Share Posted January 7, 2008 anyone know where? somewhere somehow i moved the selection box out of sight for the crop render. is it possible to reset. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted January 7, 2008 Share Posted January 7, 2008 I did this too a while back and couldn't find a reset. Try taking safe frame off though and you should be able to see it and drag it back in. Link to comment Share on other sites More sharing options...
Koper Posted January 7, 2008 Author Share Posted January 7, 2008 tried, also streched over two screens and nothing:mad: I just merged the whole scene into an older scene. that worked. thanx anyhooow;) but it will be usefull to know if somebody knows Link to comment Share on other sites More sharing options...
BrianKitts Posted January 7, 2008 Share Posted January 7, 2008 did you try reseting your UI? Link to comment Share on other sites More sharing options...
denham Posted January 7, 2008 Share Posted January 7, 2008 Have you tried to click & drag in multiple areas on the screen? For some reason my crop or region render do not show up until I do this, they are invisible until I drag, & sometimes they look all funky with overlapping crop/region windows (maybe a video card issue?) VIZ 2008 Link to comment Share on other sites More sharing options...
Koper Posted January 7, 2008 Author Share Posted January 7, 2008 did you try reseting your UI? no, but next time i will, that will probably do the job. denham, jup, it did it a second time, but this time i remembered where i put it so when i clicked and dragged it showed. this is the first time i had this and don't really know why, dont think its the video card unless mine is starting to pack its bags thanx again Link to comment Share on other sites More sharing options...
denham Posted January 16, 2008 Share Posted January 16, 2008 Just figured out how to 'reset' the crop/region box. Right Click on the upper left corner of the viewport-->configure--> Regions On the Blowup Region Panel, set the size of the region to the size you are trying to render. ex) I'm trying to render an 8000x1600 image, so I set the width to 8000 (it does not constrain proportions) Then press OK, (you might have to turn of safe frame), & it should be there. I still want to know though, why my region/crop does not appear at all until I try to inadvertantly select it & move around blindly, until it shows up somewhere. That never happened in VIZ 2007, but does in 2008. Link to comment Share on other sites More sharing options...
