stezza Posted January 8, 2008 Share Posted January 8, 2008 What is the work flow for using AutoCAD DWG files with Modo? Link to comment Share on other sites More sharing options...
4d-infinite Posted January 10, 2008 Share Posted January 10, 2008 modo can import dxf files. But, Probably better to convert dxf into lwo file first, then import it into modo. check http://www.micromouse.ca/ Link to comment Share on other sites More sharing options...
bentegviz Posted January 14, 2008 Share Posted January 14, 2008 modo can import dxf files. But, Probably better to convert dxf into lwo file first, then import it into modo. check http://www.micromouse.ca/ that's pretty much what we have to do as well. using deep exploration or accutrans. lwo gives you the least hassles in the import. Link to comment Share on other sites More sharing options...
nhayes Posted January 20, 2008 Share Posted January 20, 2008 I use dxf -> accutrans -> modo, although modo has DXF import I prefer to use accutrans as it has more options. For those that don't have AutoCAD for DWG to DXF one can use use software such as the A9 convertor: http://www.a9tech.com/products/a9converter/ Also, DWG TrueView (free from AutoDesk) is useful for converting DWG from the latest versions of AutoCAD to earlier incarnations. This can help if you're having compatibility issues when using DWG to DXF convertors. Link to comment Share on other sites More sharing options...
Sandking Posted February 3, 2009 Share Posted February 3, 2009 I'm just using native dxf import and I find quite ok after you've merged all doubled vertices. I might have a look at AccuTrans though. Link to comment Share on other sites More sharing options...
