Crazy Homeless Guy Posted January 8, 2008 Share Posted January 8, 2008 This has plagued me for awhile, and I really don't know the solution to it, but probably should by now. When working with bezier handles while in vertex mode when editing a line. ...the handles often become locked, and I can only adjust them in one direction, such as the Y direction. I should be able to adjust them in the Y, the X, or the Z direction. Other times, they are adjustable in all directions without a problem. I often switch from a bezier handle to a corner, and then back again, and occasionally that solves the problem, but not always. Anyone know how to unlock them properly? Link to comment Share on other sites More sharing options...
Gus_Rayvus Posted January 8, 2008 Share Posted January 8, 2008 click on the yellow box on the gizmo. Much like using axis constraints with the move tool. ^ | | |____ | | | | |____|________> Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted January 8, 2008 Author Share Posted January 8, 2008 hey that worked. when i first read your response, i thought the question was misunderstood about just wanting to move the handles, but it was not. thanks. Link to comment Share on other sites More sharing options...
notamondayfan Posted January 8, 2008 Share Posted January 8, 2008 or bring up the axis contraint panel and select which every axis you want the bezier to move. Link to comment Share on other sites More sharing options...
anvaraziz Posted January 9, 2008 Share Posted January 9, 2008 ^^ bring up axis constraint planel............ Link to comment Share on other sites More sharing options...
squeakybadger Posted January 9, 2008 Share Posted January 9, 2008 or press f8 when its being a bugger and not moving in your preferred direction Link to comment Share on other sites More sharing options...
only3d Posted January 11, 2008 Share Posted January 11, 2008 kind of off-topic but not that far off: is there a way to controll the nature of refined points? i mean i use refine all the time, sometimes it adds a bezier point and sometimes an ordinary one. so can i choose which one to add? Link to comment Share on other sites More sharing options...
