Sebree Posted November 6, 2002 Share Posted November 6, 2002 I have been playing around with radiosity and like what I have been able to produce but wonder if I am doing this correctly. Is it right to assume if you use radiosity in your scene that all the lights in the scene should be of photometric lights ? Or can/should you use a combination of photometric and standard lighting in a scene? Link to comment Share on other sites More sharing options...
trey Posted November 6, 2002 Share Posted November 6, 2002 after you do a radiosity solution, u can add standard lights to fill some area that are too dark. so it's ok to mix it up a little. Link to comment Share on other sites More sharing options...
ZepSOFD Posted November 6, 2002 Share Posted November 6, 2002 Sebree, You can use whatever combination of lights you want, you can always include/exclude lights from the rad. sol.. If you are doing light intensity studies, I would think you would use all IES lights, but if your just looking for well lit images, do what ever you need to, to make it work. tom Link to comment Share on other sites More sharing options...
Sebree Posted November 6, 2002 Author Share Posted November 6, 2002 Thanks for both of the comments. I'll try and experiment with all radiosity vs. combination of lights and see what works best. Use whatever works the best for me is what I am gathering. Link to comment Share on other sites More sharing options...
abicalho Posted November 6, 2002 Share Posted November 6, 2002 The reason why you should use Photometric Lights with Radiosity is because Standard Lights do not respect physical units and do render without any decay. Since the default Radiosity Rendering method is "Render Direct Illumination", the Scanline Render will render the direct light from the light itself, thus rendering the Standard Lights with no decay. If you use Re-Use Direct Illumination, than it's OK. All you'll lose is the ability to set the intensity and the specific parameters for the Photometric Lights. Alexander Link to comment Share on other sites More sharing options...
ZepSOFD Posted November 6, 2002 Share Posted November 6, 2002 A.B., Even if you set the decay of the standard lights it's still not used? tom Link to comment Share on other sites More sharing options...
abicalho Posted November 6, 2002 Share Posted November 6, 2002 If you set the decay in the lights it will still not render the same, because there's the "Decay Start" option which is not existant to Photometric Lights. It should be set for 1 meter, since it's where the intensity is 100% (intensity/1^2 = intensity) Alexander Link to comment Share on other sites More sharing options...
ZepSOFD Posted November 7, 2002 Share Posted November 7, 2002 Thanks A.B. I will keep this in mind. Link to comment Share on other sites More sharing options...
