import an 15fps image sequence in AE
Logitek
Hello,
This is probably a stupidly easy thing to do, but I just can't put my finger on it.
I'm rendering an animation in 3DMax at 15fps (it will be later on imported in Flash). I need to do some post in AE, but when I try to import the image sequence, I cannot find an option to let AE know what FPS should the image sequence be imported. So I automatically end up with a 25fps image sequence. There doesn't seem to be a way to change this setting once the sequence has been imported.
If I put this image sequence in a composition, then change my composition fps setting back to 15, it will just compress the animation and I end up with frame loss (10 out of 25!!).
Of course I could import each image one by one, but that's just a killer waste of time.
If you have an idea on how to do that, I would greatly appreciate.
Thanks a lot in advance,
Best
Matthieu DELARUE
ARCHIMED STUDIO
www.archimed-studio.com
