jophus14 Posted January 10, 2008 Share Posted January 10, 2008 I am currently working on photo matching my model to a photogragh. The model will be roughly be 6 blocks away from the camera since it has many floors and the whole building has to be seen in it's environment. My question is, is there a way to keep the same camera angle/setup and render the image out a large resolution in order to see detail? If I zoom in using the camera, I lose the correct perspective and if I raise the resolution I still an only rendering out a certain region which does me no good. The background image size is 2400 X 4200 Pixel or 16" X 28" at 150 pixels/inch. I would apprciate any responses. Thanks. Link to comment Share on other sites More sharing options...
Chad Warner Posted January 10, 2008 Share Posted January 10, 2008 You can scale the output resolution up in the rendering parameters and then render a region or a crop of just the area on the building you want to see. Link to comment Share on other sites More sharing options...
