ZFact Posted January 11, 2008 Share Posted January 11, 2008 I have a new dual quad xeon computer.. its the E5335 xeons... 2ghz - 8 cores... im considering overclocking the processors... what are your thoughts on this... bad move or not? Link to comment Share on other sites More sharing options...
ihabkal Posted January 11, 2008 Share Posted January 11, 2008 personnaly I think it is a bad move, first you will lose the warranty, second if you get obsessed with getting more power without the specialised cooling system, you will indoubtly keep cranking it up till you burn those cpus, as power usually is addictive. second your system will more likely be more unstable, and in our line of work I find stability to be much better than speed, as if it crashes too much you might lose hours of work, or ruin your hard disk and require a format to get it to work again. so keep the overclocking for gamers and hobbyists IMO. Link to comment Share on other sites More sharing options...
AJLynn Posted January 11, 2008 Share Posted January 11, 2008 So it depends on your manufacturer's warranty and how daring you feel. Link to comment Share on other sites More sharing options...
