adamantine Posted January 11, 2008 Share Posted January 11, 2008 Hello all, I'm trying to render grass using 3 simple grass geometries (with 6 poly each), put in 3 scatter compound objects. However I found out that I can't increase the duplicate value over 65000 (for each of the scatter objects). Is it the maximum limit? With 65000 duplicates, the grass still does not look tight enough. Any ideas? Thank you! Link to comment Share on other sites More sharing options...
Tim Fairbanks Posted January 11, 2008 Share Posted January 11, 2008 Just a guess, but 65,000 sounds a lot like a binary numeric limitation: 65,536 is a binary number common to computing, so it wouldn't suprise me if there is a limitation on the number of scatter objects based on some binary mathematical "logic". 3d Studio, all the way back to the old 3d Studio DOS 1&2 has had similar limitations, usually based on binary numerics. Exporting a large number of polys to .3DS format will produce a similar "error". Not that this is an explanation, in any way... TimF Link to comment Share on other sites More sharing options...
only3d Posted January 11, 2008 Share Posted January 11, 2008 my best solution to u is just not deal with it and go another way completely. vray-fur or vray disp' (if ur using vray) or 'hair&fur' modifier will give u adequette or even better results. using scatter ull get a heavy model with very long rendering time, and u dont want that. Link to comment Share on other sites More sharing options...
ipxstudios Posted January 11, 2008 Share Posted January 11, 2008 Try this plug-in if you are manually scattering grass - works pretty good. http://www.scriptspot.com/3ds-max/Advanced-Painter Link to comment Share on other sites More sharing options...
only3d Posted January 11, 2008 Share Posted January 11, 2008 Try this plug-in if you are manually scattering grass - works pretty good. http://www.scriptspot.com/3ds-max/Advanced-Painter forgot about that one. excellent tool indeed! not great for large areas though i think.. maybe more for little gardens and such. Link to comment Share on other sites More sharing options...
