atool Posted January 11, 2008 Share Posted January 11, 2008 hi, Would anybody be knowing if the 2 sided feature is possible with the A&D material? thanks Link to comment Share on other sites More sharing options...
daniohayon Posted January 14, 2008 Share Posted January 14, 2008 Hi Atool, Do you mean one side? The A&D martial is already two sided... Dani Link to comment Share on other sites More sharing options...
atool Posted January 17, 2008 Author Share Posted January 17, 2008 Hi Daniohayon, Thanks for the reply. Apparently yes, need to use it as one sided material. Was looking around for a similar checkbox as with Architectural Material & Standard Material. Would you have the solution to this please? Atool Link to comment Share on other sites More sharing options...
daniohayon Posted January 17, 2008 Share Posted January 17, 2008 OK...the other way, got it! I don't know how to do that but if you could elaborate on what you are trying to actually create in your scene I might be able to help. Regards, Dani Link to comment Share on other sites More sharing options...
jasonluckett Posted January 17, 2008 Share Posted January 17, 2008 advanced rendering option under the A&D material, check or uncheck back face culling should do the trick. jas Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted January 17, 2008 Share Posted January 17, 2008 I had trouble with this earlier today. Now I can't duplicate it. I think I solved the problem by selecting one of the templates in the A&D material then adjusted to suit my needs. Seems like a hack; maybe a better way. Let us know if this works. Link to comment Share on other sites More sharing options...
atool Posted January 22, 2008 Author Share Posted January 22, 2008 Thanks Jas, that worked for me. Link to comment Share on other sites More sharing options...
wasteland giant Posted December 22, 2009 Share Posted December 22, 2009 Hi Atool, Do you mean one side? The A&D martial is already two sided... Dani actually, I don't think this is true. I've had to convert the material to a standard material + map the thing again, because some of the material faces would render as invisible by default. Anyhow, I'll check Jas's advance material setting now. Link to comment Share on other sites More sharing options...
daniohayon Posted December 22, 2009 Share Posted December 22, 2009 actually, I don't think this is true. I've had to convert the material to a standard material + map the thing again, because some of the material faces would render as invisible by default. Anyhow, I'll check Jas's advance material setting now. Hey wasteland giant! Talk about a voice from the past...this thread is just about two years in the making...woohoo! ...anyway, the A&D mat is already set to be two sided as it's 'Back Face Culling' is unchecked by default. I'm not sure why you don't get it right of the bat, since I can't see a way to make it render on sided mat while using the default settings. Link to comment Share on other sites More sharing options...
