Aaron2004 Posted January 16, 2008 Share Posted January 16, 2008 Hello, I am using a door primitive and want to add a doorknob to it that moves with the door's swing. I can link the door knob to the door object itself, but not to the the particular element that I want. Is this possible? Also, I've searched around to no avail. Are there custom add-ons/scripts for these door primitives? They seem pretty stripped down and could use a good revamping. Thanks, Aaron Link to comment Share on other sites More sharing options...
ipxstudios Posted January 16, 2008 Share Posted January 16, 2008 You could collapse it with the door, keeping material ID's. Link to comment Share on other sites More sharing options...
ipxstudios Posted January 16, 2008 Share Posted January 16, 2008 If you are using Max doors then you may have an issue with linking the door hardware. I haven't had any luck either with those. Link to comment Share on other sites More sharing options...
Aaron2004 Posted January 17, 2008 Author Share Posted January 17, 2008 Thank you, Julian. I am just going to detach the element that I want...it seems like I can't link the door knob to it in the state it's in right now. Link to comment Share on other sites More sharing options...
