jophus14 Posted January 16, 2008 Share Posted January 16, 2008 I have attached an image of a project that I am working on and I need to apply a stainless steel material to the lighter colored objects in the image. I want the steel to be slightly different so it doesn't seem so repetative throughout the entire building. The plates will be butt-jointed with a small seam between them. My question is, how can I create the plates with a variance between them without creating thousands of individual plates and using a MultiSubObject? I was thinking of creating a box or some other type of geometry and then creating lines to use as the butt-joint for the plates. Is there anything within the Vray Material Options that I could use to my benefit? Any suggestions would help. Thanks. Link to comment Share on other sites More sharing options...
Thablanch Posted January 16, 2008 Share Posted January 16, 2008 You could do this using a tile procedural map in the shader... You do have the color variance toggle, so a simple map can give you some nice little variations. Works fine in the HGlossiness/RGlossiness slot as well, for slight variation of finish in bwtween a new and an old panel... Link to comment Share on other sites More sharing options...
