Everlasting "QUADRO" question!!!
HI!
I've been searching through quadro topics all over the magazines+internet forums for last years too much, since the GF2 is realised 'till nowadays. And I see that "quadro" mistery
is still well alive!
So, my idea is to play simply old school bench from MAX 4.2 called "bmark4" to test it, is it still worth to pay extra € for natively Quadro.
ALL are invited, please download the test for 3dsMAX from here
http://rapidshare.com/files/3108339/bmark4.rar.html
It is simply max script, if it does not start at first run, try it again and it works. I do not trust to much tp SPECViewPErf syntetic tests, 'cause this is true reallife 3dsMAX test.
PLease post your results with 1280x1024 or 1280x960 resolution, even you maybe use wide screen it doesnt matter a lot, with this res we can compare the resluts better even with some older VGA or monitor.
Have a fun!
So, here are my scores
Xeon 3210 2.13Ghz x 4
MSi 7900GTO
XP x64 SP2
169.21 WHQL Drivers, MAX 2008, 1280 x 960
4viewports.MAX | 57.6701
8direct.MAX | 456.621
8omni.MAX | 387.597
8spot.MAX | 328.407
blitting.MAX | 834.724
dualplanes.MAX | 862.999
geometry1.MAX | 349.243
geometry2.MAX | 223.38
multitex.MAX | 1.1782
rasterize.MAX | 653.168
textured1.MAX | 465.839
textured2.MAX | 169.563
textured3.MAX | 169.319
transpar.MAX | 219.106
wireframe1.MAX | 16.5517
wireframe2.MAX | 15.9464
Comp High: 147.564
Comp Low: 148.2
MSi 7900GTO
XP x64 SP2
162.25 Quadro WHQL Drivers + RT 2.06, MAX 2008
4viewports.MAX | 87.6424 52%
8direct.MAX | 512.821 12%
8omni.MAX | 400 3%
8spot.MAX | 337.268 2.70%
blitting.MAX | 969.619 16.20%
dualplanes.MAX | 908.747 5.30%
geometry1.MAX | 392.157 12.30%
geometry2.MAX | 236.967 5.80%
multitex.MAX | 1.17777
rasterize.MAX | 435.35 -45%
textured1.MAX | 494.723 6.20%
textured2.MAX | 171.821 1%
textured3.MAX | 170.184 1%
transpar.MAX | 225.428 2.70%
wireframe1.MAX | 81.3449 500%
wireframe2.MAX | 45.6066 300%
Comp High: 199.446
Comp Low: 172.065
Here's my old work computer, Viz 2007, XP SP2 32bit. Dual Xeon 3.4 (old school P4 family), with Revit running in the background. There was an image missing, "rhino" something.
Video Card: Quadro 1300 (128mb)
Display Type:1280x1024
File Name | FPS
4viewports.MAX | 60.3865
8direct.MAX | 101.626
8omni.MAX | 95.511
8spot.MAX | 83.647
blitting.MAX | 269.3
dualplanes.MAX | 87.3776
geometry1.MAX | 75.9109
geometry2.MAX | 57.1537
multitex.MAX | 26.5604
rasterize.MAX | 103.231
textured1.MAX | 96.2032
textured2.MAX | 50.3018
textured3.MAX | 533.618
transpar.MAX | 80.8016
wireframe1.MAX | 30.0511
wireframe2.MAX | 24.3982
Comp High: 67.9407
Comp Low: 89.3339
I tried running that on Max08 but there were a bunch of textures I didn't have or feel like tracking down, so some of the tests (notably multitex) aren't accurate. But...
Core2 Quad Q6600 @2880MHz
4GB RAM @320MHz
8800GTS 256MB
Direct3D
Max08 on XP32
Video Card: 8800GTS
Display Type:
File Name | FPS
4viewports.MAX | 72.7273
8direct.MAX | 492.611
8omni.MAX | 473.934
8spot.MAX | 457.666
blitting.MAX | 838.457
dualplanes.MAX | 821.355
geometry1.MAX | 362.319
geometry2.MAX | 225.904
multitex.MAX | 2.54699
rasterize.MAX | 438.404
textured1.MAX | 448.565
textured2.MAX | 196.947
textured3.MAX | 178.763
transpar.MAX | 262.329
wireframe1.MAX | 22.7514
wireframe2.MAX | 21.7202
Comp High: 168.844
Comp Low: 169.234
  • 2 weeks later...
Here are my results:
Video Card: pny 8800 geforce gtx
Display Type: Direct3D
File Name | FPS
4viewports.MAX | 71.1238
8direct.MAX | 533.333
8omni.MAX | 533.333
8spot.MAX | 512.821
blitting.MAX | 923.077
dualplanes.MAX | 903.615
geometry1.MAX | 384.123
geometry2.MAX | 243.112
multitex.MAX | 2.05922
rasterize.MAX | 520.291
textured1.MAX | 578.258
textured2.MAX | 234.88
textured3.MAX | 179.791
transpar.MAX | 307.882
wireframe1.MAX | 21.6951
wireframe2.MAX | 20.0214
Comp High: 178.569
Comp Low: 183.38
My results, again missing texture issues..
Video Card: BFG Tech 8800GTS 320MB OC2
Display Type: 1440x900
File Name | FPS
4viewports.MAX | 66.0066
8direct.MAX | 304.878
8omni.MAX | 400.0
8spot.MAX | 376.648
blitting.MAX | 780.64
dualplanes.MAX | 756.62
geometry1.MAX | 290.98
geometry2.MAX | 188.206
multitex.MAX | 1.23457
rasterize.MAX | 385.505
textured1.MAX | 335.721
textured2.MAX | 123.077
textured3.MAX | 148.148
transpar.MAX | 235.183
wireframe1.MAX | 19.1046
wireframe2.MAX | 17.9437
Comp High: 135.855
Comp Low: 131.552
Display Type: 1280 x 960
File Name | FPS
4viewports.MAX | 65.3168
8direct.MAX | 413.223
8omni.MAX | 413.223
8spot.MAX | 400.0
blitting.MAX | 813.67
dualplanes.MAX | 791.818
geometry1.MAX | 309.598
geometry2.MAX | 192.061
multitex.MAX | 1.26008
rasterize.MAX | 405.022
textured1.MAX | 337.99
textured2.MAX | 119.048
textured3.MAX | 149.522
transpar.MAX | 235.405
wireframe1.MAX | 19.0852
wireframe2.MAX | 17.7778
Comp High: 141.238
Comp Low: 134.571
Dual Core E6600 @ 2.4GHz, 2Gb RAM, 3ds max 9 32-bit
