FBM Posted January 18, 2008 Share Posted January 18, 2008 I've been spending a lot of time with VIZ lately, but I think I'm not understanding something about the VIZ daylighting system. In one of my models, I have the daylight set perfectly. I make one small change to the model (not the light), and it changes the entire lighting dramtically. I'm getting HUGE contrast between light and dark (as if it's a spotlight) and no matter how much I crank up the skylighting, it won't change. In fact, even when I change the sun intensity, nothing changes. VERY bright on the side where the sun is coming from, and VERY dark on the other. Here's what I tried. I took my scene with the perfect light. I deleted the model. I merged another file with the SAME MODEL (no lights) into the perfect lighting system. This is the same model but a few subtle changes. This changed the entire lighting and materials are not rendering the same at all. What I don't understand is why when I have my lighting setup exactly the same, but a small change in the model, the entire scene is different. Any advice? What am I missing about this daylight system? I've tried everything in the environment menu, and even when I keep it the same as the good model, things are completely different. Shouldn't the same lighting system with all the same parameters provide the same lighting in a scene with slight changes to the model? Julien Link to comment Share on other sites More sharing options...
FBM Posted January 18, 2008 Author Share Posted January 18, 2008 I really must be doing something wrong I can put the sun intensity to 0 or 10000000000, nothing changes. Same applies for the skylight. Anyone run into this? J Link to comment Share on other sites More sharing options...
kippu Posted January 18, 2008 Share Posted January 18, 2008 you should be using the exposure tool along with the daylight system... i suppose Link to comment Share on other sites More sharing options...
FBM Posted January 18, 2008 Author Share Posted January 18, 2008 I have been. The exposure seems fine. But if I try to increase daylight, nothing changes. Increase in sunlight, nothing changes. I process my radiosity solution every time. J Link to comment Share on other sites More sharing options...
