Villa
t.fzr
Hey all,
New project I'm doing. Here are a few testrenders...
Having some king of trouble with my glass, there is this deformation going on behind the glass butt I can't seem to find the solution for this... Help would be welcome ;)
Using Vray with Daylight system and physical cams
Other comments are also welcome of course :)
nice house/institution and nice start :)....fast comments
- glass: ISO = 1.0 aprox (to avoid deformations)
- huge fireplace...is it the rigth size?
- need to work u'r textures
- not crazy bout the furnitures..tho
back with more comments after watching the renders again
it would be nice to see bigger renders to make better critics/comments
cheers...Eric
It is a nice start, suggest a couple of tweaks though for your stone wall as it's so close to the camera that it needs high detail...
1. Grass texture flattens out to a green blob - maybe use displacement /or a different texture with higher resolution, make the stone wall a few centimeters higher or lower the grass plane to hide the edge of the grass (the straight edge on the grass looks odd)
2. Round-off the stone wall a bit to help the displacement or add a coping along the top - it looks great but the sharp edges kill the effect.
3. It's unclear if the water is a pool or a pond...maybe add a hand rail (pool) or aquatic plants (pond)
4. Cement render texture on the building looks out of scale - too big - at that distance it would be less prominent (in my opinion) ;)
Couple of images attached to illustrate...
Thx Shaneis this helps a lot !!
I was thinking of using a plane with some vray fur on it for the grass but maybe a displacement map should do the job as wel ... great idea to put the grass edge a little lower or higher.
The stone wall is still in construction as you can see (the sharp edge kills indeed ... will try to fix that)
The water should be a pool ... I need to add some pool furniture and maybe the water should be more transparant?
Cement is indeed to big, changed that already ;)
again a big thx
will keep you updated
  • 2 weeks later...
humm better than before...but:
if u want to keep the cam angle, then u definatelly need to fix the wall & grass textures.
u need to use a very large bitmap (pixels) for the wall and assign a uvw to make the stones size look real, then make a displacement map using the same bitmap in b&w. almost the same for the path around the pool.
for the grass, you need to use either vray displacementmod or vrayfyr. i would go for vray displacementmod which use less memory and is faster to render.
pool water...ughh no god, download a vraymat and try to get a good water colour and reflection.
pool hand rail looks white.
i suggest u 2 go 2 vraymaterials.de and try some mats for your escene
