matt_vinoir Posted July 26, 2002 Share Posted July 26, 2002 i'm being dense i know but i've just started with it! How do you rotate the map without rotatring the actual solid object. ie slate floor procedural maps. Also, i want a fluro tube to hide in a recess of thew ceiling. whats the best way to create light flooding down a wall like fluro tubes? cheers! Link to comment Share on other sites More sharing options...
quizzy Posted July 26, 2002 Share Posted July 26, 2002 rotate maps: 1. rotate the uvw map modifier gizmo (if you have one) 2. goto material editor -> select material -> goto the map you want to rotate -> every map has an offset/tiling/angle... change the z-angle (also known as the w-angle if you have an UVW... XYZ=UVW x=u and so on... greetz.... Link to comment Share on other sites More sharing options...
STRAT Posted July 26, 2002 Share Posted July 26, 2002 an easy way to create a strip of light flooding down the wall is by using a self illuminated falloff map or gradiant map in the opacity slot. here's a quick piccy i done showing a few examples of using this method - http://strat.freewebspace.com/flood.jpg if the link dont work you'll have to copy the url and paste it into the address line to see it. [ July 26, 2002, 07:48 AM: Message edited by: STRAT ] Link to comment Share on other sites More sharing options...
matt_vinoir Posted July 29, 2002 Author Share Posted July 29, 2002 i always seem to get remote linking frobiden with your images strat. shame cos i've only seen one image you'vedone and it was nice. btw i have viz 4. i forgot to say. i tried the uvw map thing. do i select the obect that the map is assigned to? the w map doesn't change anything. am i meant to go itto my mterials editor? i thought i could go to mapscaler and just rotate the map. grrr i'm so dumb! Link to comment Share on other sites More sharing options...
