Sketchrender Posted January 21, 2008 Share Posted January 21, 2008 Morning all Looking for some advise generally. 1. Do people in general have libraries set up in a base max file with Materials, ect? 2. Do you have a large set of 2D planes set up with people mapped on to them so you can merge them in? 3. Do you have base file with Vray Lights set up, a vray plane, and Vray phyiscal Cams set up? What are the short cuts you have for day to day use? Thanks phil Link to comment Share on other sites More sharing options...
BrianKitts Posted January 21, 2008 Share Posted January 21, 2008 1. Do people in general have libraries set up in a base max file with Materials, ect? 2. Do you have a large set of 2D planes set up with people mapped on to them so you can merge them in? 3. Do you have base file with Vray Lights set up, a vray plane, and Vray phyiscal Cams set up? 1. Yes/No, no it's not a max file, create for yourself a materials library (.mat) from the material editor, and then you can pull up your standard materials anytime you are working on a project. 2. No, I either use 3D people or I comp them in post. But I don't keep 2d people setup, I guess if I did them that way more often I would. But similar to what you mention, yes I have a file full of 3D people in it that I merge in for use all the time. 3. Yes, I have a scene file with a skydome, treeline, vraySun attached to a daylight settings rig, and physical camera saved out that I start every max file from. Also have the same for interior scenes with 3 typical lights (IES for flourescent, spot, and vrayLights) Link to comment Share on other sites More sharing options...
