Artifacts in Mr
kwi
I assume these artifacts or whatever they are are caused by my materials since they disappear when I render a mat override render. This is MAX 7, mentalray with a Gig of RAM on Win2K (I know I'm old).
Can some one shine some light on this?
  • 1 month later...
Hmmm... if you're doing the rendering on a farm, I'm not sure if the visual framebuffer should be an issue. When you submit the render job there is a checkbox called [ ] Rendered Frame Window (that's the same thing as Visual Framebuffer) in the *job submission* dialogue (DON'T use the one in the Render Scene window - this only applies to renderings done locally, not net renderings).
I tend to do all hi-res rendering with net rendering when using mental ray, it seems to work nicely.
Cheers
Robert
Thanks very much for your quick reply robert!
I'll see how that comes along...still working on stopping the flickering with MR animation.
Any tips?
I am using VIZ2007 MR and set a FG map...using a photon map seem to cause flickering.
Thanks again,
Rob
I have not used farm rendering. Thanks to all who replied to this post. My problem was I had too many programs running at the same time. I closed the other programs and the artifacts were gone. Memory couldn't handle all those programs. Duh!
