jorisAR Posted January 23, 2008 Share Posted January 23, 2008 Hi there, This test render contains a box with glass on each side. I used vray sun, multiplier 0.3 is the only thing I changed. I also used the default background, vraysky. Vray physical camera, shutter speed 50. In render dialog (F10) environment NOTHING is checked. The problem is that in the renderpasses the background looks good, but when the render is done, the background is completely white, except for the part you see through the glass. How is this possible, what can I do to solve this, to see the background in the rest of the render too. The glass settings is not the problem I think. Hope someone can help me..... greetz Link to comment Share on other sites More sharing options...
jorisAR Posted January 23, 2008 Author Share Posted January 23, 2008 Ok, I found out the problem myself. Just had to play a little more with the settings of the sun and the camera. After playing around with, f-number, shutterspeed, multiplier.... I found out that the background was just burnt with sunlight. I posted it, cause it's an urgent assignment for tomorrow, but everything is going to be allright greetz Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted January 23, 2008 Share Posted January 23, 2008 Please, next time post VRay-related questions in the VRay section of our forum. Thank you. Link to comment Share on other sites More sharing options...
