Help with getting roof right please
Billabong
I have these slanted roofs that are suppose to go over the balconies, and the roofs are that Spanish tile. I cannot figure out how this roof is supposed to be shaped. I only have the front blueprint of the roof and an arial view of the balcony, which I also attached. the way I have right now, I dont thin its suppose to be. I just dont see how the tile would look right, but if I remove that edge, then the entire balcony won't be covered unless I bring the roof out farther than it should be.I really appreciate any help
I can't quite tell if the roof pitches are all the same, but generally that should be the case.
You're using Vray right? Why don't you make a gradient ramp map and use that as a quick displacement on the roof planes you've already got-just to see what it looks like. That way you don't have to model all of the tiles until you're sure you like the look of it.
