kusa Posted January 26, 2008 Share Posted January 26, 2008 I recently upgraded from archicad 8.1 to archicad 11. Everything worked fine until I tried using the object libraries. I keep getting error messages, and the model will not display in the 3d window. Initially I thought this was an installation problem, but after reinstalling the program thrice, i m really at my wits end. Any suggestions... Thanks. Link to comment Share on other sites More sharing options...
Derek Entesano Posted February 5, 2008 Share Posted February 5, 2008 Archicad 8.1 to 11 is a pretty big jump, you will have object problems. All I can recommend is saving the file out of 8.1 as a .PLA so that only the objects used are embedded then open it in 11. A reason the file may not be showing in 3D is that the 3D cutting plane may be on, you can find that in View>Elements in 3D View pulldown menu. I think the hotkey for it can be down accidentally quite easily! Link to comment Share on other sites More sharing options...
kusa Posted February 5, 2008 Author Share Posted February 5, 2008 Thanks. I actually solved the problem by uninstalling and reinstalling the program to restore the default settings.. Thanks again... Link to comment Share on other sites More sharing options...
