xchylar Posted January 26, 2008 Share Posted January 26, 2008 i tried the usual stuff: camera> parallel projection> camera > standard views> front. then plugins> vray for sketchup> render. the image i get is still in PERSPECTIVE view. i think the problem is in the v-ray settings, and i'm totally clueless . im in need of help guys. thanks in advance! Link to comment Share on other sites More sharing options...
andriyg81 Posted January 26, 2008 Share Posted January 26, 2008 in order to render elevation make sure you uncheck Physical camera in vray settings. You probably will need to tweak lights after that but it will let you render an elevation Link to comment Share on other sites More sharing options...
fonnsarch Posted December 18, 2008 Share Posted December 18, 2008 I have the same problem so I unchecked the physical camera and set default camera for "standard type" but after rendering the picture is so brightness (be a white plane) in RGB viewing but i can see it in alpha view How I can adjust anymore? thank you Link to comment Share on other sites More sharing options...
AJLynn Posted December 18, 2008 Share Posted December 18, 2008 You're probably overexposing - you've got a sun system that's in physical units and if you're not in physical camera units you blow it out. Same deal in all the Vray implementations that hav physical sun. You need to either be working in physical sun / physical camera or bring the sun down to the units the normal camera can handle. I'd tell you how to do this but I've never used Vray in Sketchup... but if the sun has a multiplier try setting it low, start at .01 and go from there. Link to comment Share on other sites More sharing options...
DJ.Rosenbaum Posted January 15, 2010 Share Posted January 15, 2010 I was having the same problem with Vray for Rhinoceros. To solve this problem 1. Use a Default Camera "standard type" 2. Lower your Sun's Intensity mult. to around .02 3. Under Environment GI Skylight also lower Intensity mult. to around .02 Link to comment Share on other sites More sharing options...
