Neil Woodhouse Posted January 28, 2008 Share Posted January 28, 2008 Hi all, OK, I'm putting my head on the block with this one. Attached is an image which i have recently produced. The client tells me the lighting is flat. Done in V-Ray 1.5. Spherical HDRI Sky ( which as i mentioned in another thread seems to be out of proportion to the image that is in the M/Editor ) One direct light perpendicular to the camera. Rendered out it seemed over bright. Saved as a jpeg this is what came out of PS ( no adjustments ) So. What's wrong with it? How can it be improved. Trees are a mixture of Speedtree & Evermotion, fence is from Dosch. I like the shadows and i'm fairly happy with the glass, but the rest!!! you tell me. It's really starting to frustrate me. Regards Neil Link to comment Share on other sites More sharing options...
Horhe Posted January 28, 2008 Share Posted January 28, 2008 What colour mapping are you using? Looks like exponential or reinhard with a low burn value... thus the foggy look.. Link to comment Share on other sites More sharing options...
Neil Woodhouse Posted January 28, 2008 Author Share Posted January 28, 2008 Hi, Colour mapping is: Linear Multiply. Dark = 1 Bright = 0.5 Gamma = 1 Affect Background = on ( ticked ) Link to comment Share on other sites More sharing options...
BN11 Posted January 28, 2008 Share Posted January 28, 2008 Hi Neil, Not sure how you've set up your HDRI, but the background does not help your image. If I was you I would keep things simple to start with & switch off the HDRI settings, still keep the direct light with vray shadows & use a nice landscape (trees/sky) background in the max enviromental slot. Try looking at improving your textures, the brickwork map (std autodesk brick map) is way too large & the grass / paving could be better. Plenty of texture resources are available.....listed here on CG Architect Once your happy with your standard direct lighting & textures, THEN start experimenting with HDRIs....again there are many tutorials & techniques on setting up HDRIs Good Luck & keep posting your results Link to comment Share on other sites More sharing options...
Tommy Burns Posted January 28, 2008 Share Posted January 28, 2008 Yes I agree about the brickwork it is way off scale need to work on your mapping/tiling smaller bricks would make a big diff. It is really worth it to learn how mapping and tiling work properly. Things look better and you save a lot of time trying to guess it Link to comment Share on other sites More sharing options...
Neil Woodhouse Posted January 29, 2008 Author Share Posted January 29, 2008 Ok, Here's an upgrade. Increased the bright to 1.0 Got rid of the HDRI Reduced the size of the brick texture gone back to an old favourite grass map How's it stacking up now? Link to comment Share on other sites More sharing options...
Neil Woodhouse Posted January 29, 2008 Author Share Posted January 29, 2008 Image too large. Post later. Sorry Link to comment Share on other sites More sharing options...
Neil Woodhouse Posted January 30, 2008 Author Share Posted January 30, 2008 Here we go, sorry about this. Link to comment Share on other sites More sharing options...
e_cbautista Posted January 30, 2008 Share Posted January 30, 2008 i like the grass and plants. the brickwork however still seems too large. i suggest using "real world scale" and adjust the map size accordingly. then use uwvmap modifier, usually "box" works. Link to comment Share on other sites More sharing options...
Eric Sosa Posted January 30, 2008 Share Posted January 30, 2008 hey Neil. my suggestion: - vray sun max 0,003 shadows subv at 15 or 20 - vray enviromental ligth at 0,2-0,3 with an sligth ligth blue colour on - either standard cam or vray physical cam without focus..with focus; shooter speed at 2.0 and ISO at 200 you will get a good star render and THEN, you can try to adjust the colour mapping and HDR's after! I made a small vray tutorial explaining lumination for exteriors and interiors http://www.vray-materials.de/forum/showthread.php?tid=320 hope you can use it...good luck; Eric Link to comment Share on other sites More sharing options...
Dave Buckley Posted January 30, 2008 Share Posted January 30, 2008 my suggestion is buy the latest edition of 3d world, all about arch viz with vray Link to comment Share on other sites More sharing options...
Eric Sosa Posted January 30, 2008 Share Posted January 30, 2008 L:)L....besides Link to comment Share on other sites More sharing options...
Ray Posted January 30, 2008 Share Posted January 30, 2008 You're also missing a texture on those leaves in the foreground, right side. Link to comment Share on other sites More sharing options...
Neil Woodhouse Posted January 30, 2008 Author Share Posted January 30, 2008 So i am. That's odd, it's an evermotion tree, that should map automatically and i don't think i proxied any of them. Mmmmm Link to comment Share on other sites More sharing options...
