Michael J. Brown Posted January 28, 2008 Share Posted January 28, 2008 Max 2008 has a new interface for the "Select by Name" dialog that is driving me absolutely INSANE!!! I'm sure I'm not alone in my delirium. Unless, that is, I'm the only clown left who hasn't found how to collapse all those (needless) object display trees and whatnot. This dialog use to be so simple to use in Max9. Now they've gummed it all up with endless geneologies of every object, sub-ojbect and distant cousin related to said object. I know about the "Display" buttons near the top of the dialog for narrowing down the search fields. And I know about disabling the "Children" option under the Display pulldown. But even after having done this, it seems there is much more information being displayed than what is necessary (for architectural visualization purposes, that is). It takes me intirely too long to sift and scroll through the mile-long list of scene objects to find what i'm looking for. And don't let me need to select multiple objects that aren't next to each other on the list...ARGHHHH:mad: I'm only using Max2008 here at work. But as far as upgrading to it for my home office...THIS IS A DEAL BREAKER. :mad: Has anybody found a way to make this dialog simplify the display of scene objects to the break-down Max9 gives? Link to comment Share on other sites More sharing options...
caffa Posted January 28, 2008 Share Posted January 28, 2008 I agree: the "Select by Name" dialog now sucks. I'm using the "Selection Floater", it's identical to the old "Select by Name". Link to comment Share on other sites More sharing options...
CRD Posted January 28, 2008 Share Posted January 28, 2008 We were irritated by this change also, and after searching we found this fix: To put it back to the old dialog, open your currentdefaults.ini, and change this line: SelectByNameUsesSceneExplorer=0 It’s set to 1, just change it to 0 and save. The ini is located here: C:\Documents and Settings\username\Local Settings\Application Data\Autodesk\3dsmax\2008 - 64bit\enu\defaults\MAX I wish I could credit the source, but I forgot where we found the answer. Link to comment Share on other sites More sharing options...
Michael J. Brown Posted January 28, 2008 Author Share Posted January 28, 2008 I agree: the "Select by Name" dialog now sucks. I'm using the "Selection Floater", it's identical to the old "Select by Name". caffa, you are 'the man'. This makes everything bearable once again. Thanks, also, CRD. I may try your solution also. But now that I've found the "Selection Floater" and added it's button to my interface I think i'm good to go. THANKS!! Link to comment Share on other sites More sharing options...
caffa Posted January 28, 2008 Share Posted January 28, 2008 We were irritated by this change also, and after searching we found this fix: To put it back to the old dialog, open your currentdefaults.ini, and change this line: SelectByNameUsesSceneExplorer=0 It’s set to 1, just change it to 0 and save. The ini is located here: C:\Documents and Settings\username\Local Settings\Application Data\Autodesk\3dsmax\2008 - 64bit\enu\defaults\MAX I wish I could credit the source, but I forgot where we found the answer. Thanks Colin, it's a brilliant and definitive solution for me Link to comment Share on other sites More sharing options...
Michael J. Brown Posted January 28, 2008 Author Share Posted January 28, 2008 We were irritated by this change also, and after searching we found this fix: To put it back to the old dialog, open your currentdefaults.ini, and change this line: SelectByNameUsesSceneExplorer=0 It’s set to 1, just change it to 0 and save. The ini is located here: C:\Documents and Settings\username\Local Settings\Application Data\Autodesk\3dsmax\2008 - 64bit\enu\defaults\MAX I wish I could credit the source, but I forgot where we found the answer. Yeah, this one's a keeper. I decided to just delete the extra "Selection Floater" button I had created and go with this .ini mod. Thanks Colin. Link to comment Share on other sites More sharing options...
kippu Posted January 28, 2008 Share Posted January 28, 2008 thanks CRD....that was a major pain Link to comment Share on other sites More sharing options...
ipxstudios Posted January 28, 2008 Share Posted January 28, 2008 Thanks so much! I was frustrated with that one too! Link to comment Share on other sites More sharing options...
Brian Cassil Posted January 28, 2008 Share Posted January 28, 2008 Thanks from me too... In fact if anyone is keeping score count me for three. We've been going battty with the new dialogue! And I gave it a real earnest effort. Link to comment Share on other sites More sharing options...
Chad Warner Posted January 28, 2008 Share Posted January 28, 2008 I tried it for about a week and couldn't deal with it. Link to comment Share on other sites More sharing options...
Justin Hunt Posted January 29, 2008 Share Posted January 29, 2008 I dont know I kind of like it, I got rid of all the extra columns and defaulted it to not show sub tree. I do find the colours difficult to read though. I use the layer manager more than select by name wich makes scene exploration much easier. The Select similat is fantastic, just select one object, hit ctrl Q and the the relevant objects are selected. JHV Link to comment Share on other sites More sharing options...
ihabkal Posted January 29, 2008 Share Posted January 29, 2008 yeah the new dialogue takes 5 minutes or much more to open depending on how many objects you have in the scene. One of the latest projects had 25.5 million polys, and if you hit the new select by name button, it takes many many hours. once you hit it you will have to stop max using the task bar end "process" and restart max, and reopen that giant file. I was so happy to have found the old selection tool when I searched for a solution online... Link to comment Share on other sites More sharing options...
Michael J. Brown Posted January 29, 2008 Author Share Posted January 29, 2008 One of the latest projects had 25.5 million polys... WHOA!!! 25.5 million polys? What kind of setup are you running to even handle all of that? the most I've ever had at one time is about 3.5 million. Of course, my models have been all restricted to several rooms within a singular building - versus say, an entire campus of buildings or the like. Link to comment Share on other sites More sharing options...
gerard Posted January 29, 2008 Share Posted January 29, 2008 Thank you very much. Its such a relief........ Link to comment Share on other sites More sharing options...
Justin Hunt Posted January 29, 2008 Share Posted January 29, 2008 remove all columns that arent needed ,like the hidden, frozen , face count etc. then it will open just as quick as the old one. JHV Link to comment Share on other sites More sharing options...
ant_march Posted January 31, 2008 Share Posted January 31, 2008 Ay, select by name in the new 2008 is a complete pain. I have another problem though, I found the solution in the Max help files that is listed below, and I have changed the CustomDefaults.ini file as suggested to.. Select ByNameUsesSceneExplorer=0 but it still doesn't bring back the old Selection Floater. !!!!!!!!!!! Anyone have any ideas as to why. The only differences I can see to the solution below is that I'm using 32bit v2008 and I've installed to my D drive rather than my C drive, hence putting my CustomDefaults.ini file in a subfolder of Max 2008 rather than in Documents and Settings. I'm looking all over my C drive too but can't find any other CustomDefaults.ini Autodesk drive me round the .?£%>? bend, on a regular basis.!!!! Tony Link to comment Share on other sites More sharing options...
Michael J. Brown Posted January 31, 2008 Author Share Posted January 31, 2008 ...The only differences I can see to the solution below is that I'm using 32bit v2008... I'm running the 32-bit version too, and this fix has worked fine for me. ...and I've installed to my D drive rather than my C drive, hence putting my CustomDefaults.ini file in a subfolder of Max 2008 rather than in Documents and Settings... It sounds to me like you may not have changed the .ini file that Max is pulling from. Try doing a search for all "currentdefaults.ini" files on both your C: and D: drives. Then just make that change to all of them. Link to comment Share on other sites More sharing options...
ant_march Posted February 1, 2008 Share Posted February 1, 2008 Have found the necessary ini file and amended it. I have the selection floater back now. One other note, don't know if anyone has noticed this or whther its just the file I'm working on, but the rename objects utility seems to take forever to work. I'm renaming just short of 200 objects, and its taking about ten times longer than Max 8 , (we never used Max 9 in here), in fact its still going, as long as its taken me to open my explorer, log into CG architect site and type and post this e-mail. !!! this is crap.! Just finished 193 objects renamed, at least 6 minutes.!!!! Link to comment Share on other sites More sharing options...
kulbir bal Posted February 1, 2008 Share Posted February 1, 2008 Thanks from me too Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted February 1, 2008 Share Posted February 1, 2008 Is there anyone runing Quadro w/MAX 2008? Still problems with new selection set? Link to comment Share on other sites More sharing options...
