ap3 Posted January 30, 2008 Share Posted January 30, 2008 Hi there, I'm not a computer expert, i just want to get a new laptop to handle my rendering job, i'm using 3dsmax, autocad and photoshop (may use vray in near future) i heard about vista not quite complarable with max, my existing computer running winxp 32bit so far so good but found this one online recently with the followings:- 17" WXGA+HD widescreen (window vista) Intel core 2 due (2b)(2c)(3)(4b) 512 nvidia geforce 8600GS 3GB memory 320GB hard drive Please advise. Thanks AP Link to comment Share on other sites More sharing options...
dbibb Posted January 30, 2008 Share Posted January 30, 2008 I have an HP dv6500 laptop with vista 32 bit. I run max 9 and 2008, vray 1.5, photoshop, and autocad 2005 on it. Autocad was the only one that was a bit tricky to set up, but a quick environment variable fixed it. I hear this isn't an issue anymore with 2007. I don't use my laptop for any heavy work, but it works great for running a small side project, or ps work while my workstation is rendering. By the way, if you use a laptop next to your workstation, check out Synergy2 http://synergy2.sourceforge.net/ Link to comment Share on other sites More sharing options...
AJLynn Posted January 30, 2008 Share Posted January 30, 2008 Doesn't WXGA+ mean 1440x900? That's really low res on a 17" screen. Also, which Core 2 Duo is it? Link to comment Share on other sites More sharing options...
ap3 Posted January 31, 2008 Author Share Posted January 31, 2008 Hi AJLynn, Yes, it is 1440x900 but not quite sure which Core 2 Due? but how about this one just found from costco, current computer running 3dsmax9, photoshop cs2, autocad-04 will upgrade to 2006 & install Vray in the near future. Intel® Core™ 2 Duo Processor T7250 (2.0GHz) Microsoft® Windows Vista Home Premium (32-bit) 2MB L2 cache 800MHz front side bus 2GB DDR2 SDRAM (2 x 1024MB); maximum capacity 4GB 320GB (5,400RPM) SATA dual hard drive (160GB x 2) LightScribe 8x DVD±RW drive with Double Layer Support 17.0" WSXGA+ BrightView widescreen display; 1680 x 1050 native resolution 256MB NVIDIA® GeForce® 8400M GS graphics Please give comment on this one too. Thanks. Ann Link to comment Share on other sites More sharing options...
ap3 Posted January 31, 2008 Author Share Posted January 31, 2008 Hey dbibb, That's exactly what i'm trying to do, while workstation is rendering i can work on other application, the new laptop as a desktop replacement by the way can i hook up with 21" monitor? Thanks for your info. Ann Link to comment Share on other sites More sharing options...
dbibb Posted January 31, 2008 Share Posted January 31, 2008 Ann, Either one of those laptops should be fine for you, depending on the size of your typical max scene. The graphics card is what will help your viewport performance. I have the geforce 8400M GS, and it works fine. You should have no problem attaching an extra 21" monitor to your laptop. If you're on a network with a domain make sure that the version of vista that you're getting allows you to connect to a domain. I know that vista business does, not sure about the others. Link to comment Share on other sites More sharing options...
ap3 Posted January 31, 2008 Author Share Posted January 31, 2008 Ann, Either one of those laptops should be fine for you, depending on the size of your typical max scene. The graphics card is what will help your viewport performance. I have the geforce 8400M GS, and it works fine. You should have no problem attaching an extra 21" monitor to your laptop. If you're on a network with a domain make sure that the version of vista that you're getting allows you to connect to a domain. I know that vista business does, not sure about the others. Dbibb, thanks for your reply, so is time to get vista now and how can i get the info to make sure vista home edition can connect to a domain before go for it, wait... is there any problem on a network for differ windows platform? Ann Link to comment Share on other sites More sharing options...
