maxiedaman Posted January 31, 2008 Share Posted January 31, 2008 I'm making neon lights for a city. I press F9 and I get this message saying: PHEN 0.3 error 051011: shader "max_is_material_editor" not found PHEN 0.3 error 051011: shader "max_DefaultMaterial" not found PHEN 0.3 error 051011: shader "max_SpotLight" not found PHEN 0.3 error 051011: shader "max_OmniLight" not found PHEN 0.3 error 051011: shader "max_base_Curve" not found PHEN 0.3 error 051011: shader "max_base_CurveControl" not found PHEN 0.3 error 051011: shader "max_base_Output" not found PHEN 0.3 error 051011: shader "max_Falloff2" not found PHEN 0.3 error 051011: shader "max_base_BlinnIllumination" not found PHEN 0.3 error 051011: shader "max_StandardMaterial" not found PHEN 0.3 error 051011: shader "max_base_UVGenerator" not found PHEN 0.3 error 051011: shader "max_Bitmap" not found PHEN 0.3 error 051011: shader "max_Environment" not found PHEN 0.3 error 051011: shader "max_base_GBuffer_lens" not found PHEN 0.3 error 051011: shader "max_base_VideoColorCorrect" not found PHEN 0.3 error 051011: shader "max_base_ImageCollector" not found PHEN 0.3 error 051011: shader "max_base_VideoSuperBlack" not found PHEN 0.3 error 051011: shader "max_DefaultLight" not found PHEN 0.3 error 051011: shader "max_is_material_editor" not found PHEN 0.3 error 051011: shader "max_DefaultMaterial" not found PHEN 0.3 error 051011: shader "max_SpotLight" not found PHEN 0.3 error 051011: shader "max_OmniLight" not found PHEN 0.3 error 051011: shader "max_base_Curve" not found PHEN 0.3 error 051011: shader "max_base_CurveControl" not found PHEN 0.3 error 051011: shader "max_base_Output" not found PHEN 0.3 error 051011: shader "max_Falloff2" not found PHEN 0.3 error 051011: shader "max_base_BlinnIllumination" not found PHEN 0.3 error 051011: shader "max_StandardMaterial" not found PHEN 0.3 error 051011: shader "max_base_UVGenerator" not found PHEN 0.3 error 051011: shader "max_Bitmap" not found PHEN 0.3 error 051011: shader "max_Environment" not found PHEN 0.3 error 051011: shader "max_base_GBuffer_lens" not found PHEN 0.3 error 051011: shader "max_base_VideoColorCorrect" not found PHEN 0.3 error 051011: shader "max_base_ImageCollector" not found PHEN 0.3 error 051011: shader "max_base_VideoSuperBlack" not found PHEN 0.3 error 051011: shader "max_DefaultLight" not found Is There anyway that I can fix that? Link to comment Share on other sites More sharing options...
maxiedaman Posted January 31, 2008 Author Share Posted January 31, 2008 Also, those spheres in the material wont show, and it's pure black. Link to comment Share on other sites More sharing options...
Tommy Burns Posted January 31, 2008 Share Posted January 31, 2008 Looks like you need a re-install of max cos you have lost a lot of links there unless someone knows where to find them again? Link to comment Share on other sites More sharing options...
maxiedaman Posted January 31, 2008 Author Share Posted January 31, 2008 Everything's there. It's mental ray that I'm having problems with, cause I just used it an hour ago, I didn't delete anyhing, and the message pops up on my screen. Link to comment Share on other sites More sharing options...
Tommy Burns Posted January 31, 2008 Share Posted January 31, 2008 Maybe a restart might do it or else create a new scene and merge? Link to comment Share on other sites More sharing options...
maxiedaman Posted January 31, 2008 Author Share Posted January 31, 2008 Didn't work. Link to comment Share on other sites More sharing options...
maxiedaman Posted January 31, 2008 Author Share Posted January 31, 2008 Hi Micheal, Any chance you can post your scene? If we can use it OK then it is going to be a local problem! If not then something in the scene is not playing nice. Regards Bri How do u do that. Sry. I'm new here. Link to comment Share on other sites More sharing options...
maxiedaman Posted January 31, 2008 Author Share Posted January 31, 2008 It's working now. The stupid program was playing mindgames with me. Link to comment Share on other sites More sharing options...
MasterZap Posted February 11, 2008 Share Posted February 11, 2008 The only thing that would give this result would be one of: - you deleted 3dsmaxXXXX.dll (XXXX is your max version, i.e. 9, 2008, etc.) in the \mentalray\shaders_standard\shaders\ - you deleted some other DLL that file depends on - your computer is having a massive issue somewhere, perhaps harddisk going on the fritz These messages is simply telling you that these shaders couldn't be found (as in "loaded"). All these are standard shaders from the 3dsmaxXXXX.dll file. So they should always be there in a correct installation. You shouldn't even be able to get rid of them without somehow screwing up the 3dsmaxXXXX.dll or any of it's dependencies.... /Z I'm making neon lights for a city. I press F9 and I get this message saying: PHEN 0.3 error 051011: shader "max_is_material_editor" not found PHEN 0.3 error 051011: shader "max_DefaultMaterial" not found PHEN 0.3 error 051011: shader "max_SpotLight" not found PHEN 0.3 error 051011: shader "max_OmniLight" not found PHEN 0.3 error 051011: shader "max_base_Curve" not found PHEN 0.3 error 051011: shader "max_base_CurveControl" not found PHEN 0.3 error 051011: shader "max_base_Output" not found PHEN 0.3 error 051011: shader "max_Falloff2" not found PHEN 0.3 error 051011: shader "max_base_BlinnIllumination" not found PHEN 0.3 error 051011: shader "max_StandardMaterial" not found PHEN 0.3 error 051011: shader "max_base_UVGenerator" not found PHEN 0.3 error 051011: shader "max_Bitmap" not found PHEN 0.3 error 051011: shader "max_Environment" not found PHEN 0.3 error 051011: shader "max_base_GBuffer_lens" not found PHEN 0.3 error 051011: shader "max_base_VideoColorCorrect" not found PHEN 0.3 error 051011: shader "max_base_ImageCollector" not found PHEN 0.3 error 051011: shader "max_base_VideoSuperBlack" not found PHEN 0.3 error 051011: shader "max_DefaultLight" not found PHEN 0.3 error 051011: shader "max_is_material_editor" not found PHEN 0.3 error 051011: shader "max_DefaultMaterial" not found PHEN 0.3 error 051011: shader "max_SpotLight" not found PHEN 0.3 error 051011: shader "max_OmniLight" not found PHEN 0.3 error 051011: shader "max_base_Curve" not found PHEN 0.3 error 051011: shader "max_base_CurveControl" not found PHEN 0.3 error 051011: shader "max_base_Output" not found PHEN 0.3 error 051011: shader "max_Falloff2" not found PHEN 0.3 error 051011: shader "max_base_BlinnIllumination" not found PHEN 0.3 error 051011: shader "max_StandardMaterial" not found PHEN 0.3 error 051011: shader "max_base_UVGenerator" not found PHEN 0.3 error 051011: shader "max_Bitmap" not found PHEN 0.3 error 051011: shader "max_Environment" not found PHEN 0.3 error 051011: shader "max_base_GBuffer_lens" not found PHEN 0.3 error 051011: shader "max_base_VideoColorCorrect" not found PHEN 0.3 error 051011: shader "max_base_ImageCollector" not found PHEN 0.3 error 051011: shader "max_base_VideoSuperBlack" not found PHEN 0.3 error 051011: shader "max_DefaultLight" not found Is There anyway that I can fix that? Link to comment Share on other sites More sharing options...
maxiedaman Posted February 11, 2008 Author Share Posted February 11, 2008 It's okay. I got it working now. I jus had to close it and open the program again. Nothing wuz deleted. Link to comment Share on other sites More sharing options...
Tommy Burns Posted February 11, 2008 Share Posted February 11, 2008 I don't understand are you saying that all this time you never restarted the program?? Link to comment Share on other sites More sharing options...
