Guest nazcaLine Posted February 2, 2008 Share Posted February 2, 2008 in windows xp, is there a way to create a new folder in the explorer with only a keyboard shorcut? for example F11, or any other shortcut. i checked the windows help and there's none for this. thanks for your help Link to comment Share on other sites More sharing options...
Horhe Posted February 2, 2008 Share Posted February 2, 2008 You can get Total Commander to browse your hard drive - the shortcut there is F7. http://www.ghisler.com/ http://www.ghisler.com/picture.htm - and this is a preview - the shortcut is at the bottom there - F7 new folder As far as Windows browsing goes - if you want to create a folder entirely by keyboard you can: Press the key between the right 'windows' key and the right 'ctrl' key. Then use the arrows to select -> new -> folder. Link to comment Share on other sites More sharing options...
BrianKitts Posted February 3, 2008 Share Posted February 3, 2008 To do it with only windows and no external prog..... right click on the folder and make a shortcut to it. Then drag the shortcut to your desktop, right click on the shortcut and select properties. In there you can assign a shortcut key to it. Only drawback is that if you want the shortcut key to be always available you have to leave the shortcut icon on your desktop. I don't think it works if the shortcut icon is buried in a sub-folder. I've never figured out how to assign hotkeys to the actual folder itself, but assigning a key to a shortcut icon of the folder is simple. Otherwise you'd have to use a third party ap. Link to comment Share on other sites More sharing options...
