lyca Posted February 4, 2008 Share Posted February 4, 2008 Hi all After completing a project in Max/Vray, i would like to export the project with all shader and texture to a realtime engine, i'd like to ask if anyone knows a realtime engine for max with who it's easy to export a project or do i have to redo all the textures one by one for example if i want to use Quest 3D ? Link to comment Share on other sites More sharing options...
Devin Johnston Posted February 4, 2008 Share Posted February 4, 2008 This has been talked about many times before and the consensus is that there is no real-time engine out there that can easily take a model from a standard 3D package. The problem is that most engines use their own shaders and lighting systems and there is no way to directly export a model into these engines with all of those elements intact. You would have to import the geometry and then completely rework the model in order to have something that would function in a real-time engine. You will also have to edit the model to get the geometry as simple as possible in order for most engines to be able to handle it. Link to comment Share on other sites More sharing options...
lyca Posted February 5, 2008 Author Share Posted February 5, 2008 Even if it is not the answer I was especting , I thank you Maxer, at least i'v got a clear answer. As we always say here in Luxembourg "let's go to work ! and do all this work manualy guys" Link to comment Share on other sites More sharing options...
notamondayfan Posted February 5, 2008 Share Posted February 5, 2008 i know its not vray, but i think fryrenderer has a automated realtime conversion thingy. quest 3d is a good option tho, as you can export several uvw maps for each object. ive been experimenting with quest and getting some really nice results using vray and baking the lighting. Link to comment Share on other sites More sharing options...
Simon Moir Posted February 5, 2008 Share Posted February 5, 2008 I like this one: http://www.vertice.fr/ Link to comment Share on other sites More sharing options...
