smr_VIZ Posted February 4, 2008 Share Posted February 4, 2008 Through my test and some tutorial, I think VRay use Refraction to control a material's transparency. So if I applied a little bit of grey to Refraction slot, then the material will become transparent. the value 1 equals to 100% transparency. Can any expert confirm this? Link to comment Share on other sites More sharing options...
Tommy L Posted February 4, 2008 Share Posted February 4, 2008 Yes, you also have an opacity slot in the maps.What are you trying to do? Link to comment Share on other sites More sharing options...
smr_VIZ Posted February 4, 2008 Author Share Posted February 4, 2008 Yes, you also have an opacity slot in the maps.What are you trying to do? I am trying to create a glass curtain wall for a highrise. I used to use falloff for opacity map to create transparency. But other people told me the right way to do it in VRay is using refraction. Link to comment Share on other sites More sharing options...
Tommy L Posted February 4, 2008 Share Posted February 4, 2008 Yes. Put the falloff map into the refraction swatch. Do you understand how falloff works? Link to comment Share on other sites More sharing options...
