Switching to the Sunny-16 Technique, but have dark sky...
RyanSpaulding
Hey guys,
I've been using the lele method up until now to get accurate results with my VRay scenes. It for the most part did work, but I had issues with the image being too dark, and when I bumped up brightness with the ISO, my colors became washed out...which then had to have major color correction in PS to match the samples.
I've looked into the Sunny-16 rule and like the output a bit better, but the only thing not working is the sky...it's way too dark. For those who use the sunny-16 system...do you have a way to brighten just the sky up with some sort of multiplier? Or are you placing a plane with a sky bitmap in the background typically?
sounds like you are doing way too much fudging.... are you doing any gamma correction? LWF?
  • 1 month later...
  Chad Warner said:
just check "manual sun node" in the sky's map slot, and you can adjust the intensity to whatever suits you. As long as you copied (not instanced) the sun, it won't effect Vray's environment map. (unless of course you're not using it in the VRay environment.
Hey Chad, I forgot to thank you on this one. However, I'm noticing that when I do this, I'm actually adding more blue from the sky's intensity into the scene that bounces on other objects and am also getting slight bleeding in color due to more light hitting and bouncing.
Is there a way to just brighten the sky w/o adding more light? Sort of like a manual override.
if you drag your Vray sky from the environment slot, to the material editor, and instance it, you will see then all the settings for the sky. You can then choose your sky node, which is the vray sun in your scene.
A lot of settings and colours can be controlled from here. Also, if you are getting too much blue from the scene, change your vray physical camera settings for the white balance.
That's exactly what I'm doing though. My white balance is a light orange hue (rgb = 251/218/175) btw. Camera is using the sunny 16 rule so it's all default except for f-stop (16) and iso (90). Sun is also default.
Ok, here's the process (using VRay 1.5 S1 btw):
1. Place sun (materials are accurate, bounces dont bleed, but sky is too dark)
2. I go to the environment tab, drag the sky to the material editor as an instance
3. Check 'manual sun node'
4. Increase the multiplier to 2
5. Render
This makes the sky the way I want it, but the blue it casts is now multiplied by 2. This creates a 'cold' feeling throughout the scene.
I'll render out some images to show what I'm talking about.
It's a two step process. Instance the vray skymap out of the environment tab, but then clone it in the material editor. Drag the clone into the "override max environment" slot in the Vray settings Tab. Then you can change the original instance to manual sun mode, and change as you wish, but it won't effect the environment light, which is now being overridden by the clone.
This probably doesn't make much sense.
