DAN212222 Posted February 6, 2008 Share Posted February 6, 2008 hi guys got a bit of problem, i have a material applied to a number of objects and its the projection is set as spherical, i need to update the model to have a projection of cubic, and was wondering if there is a way of doing it without clicking every object and changing it? thanks dan Link to comment Share on other sites More sharing options...
mr. a Posted February 6, 2008 Share Posted February 6, 2008 Might not be the exact solution you are looking for: -From the material editor, select objects via the material in question -Apply a new UVW map modifier to the selected objects with the desired projection -This modifier is now instanced and overrides any UVW modifier beneath it in the stack that has the same number Hope this helps. Link to comment Share on other sites More sharing options...
jackb602 Posted February 6, 2008 Share Posted February 6, 2008 Select the material in question in the Material Manager. In the Material Manager, select Function>Select Texture Tags/Objects. This selects all tags that refer to the chosen material. In the Attribute Manager, set the projection to cubic. Done! Jack Link to comment Share on other sites More sharing options...
DAN212222 Posted February 7, 2008 Author Share Posted February 7, 2008 Spot On Cheers! Link to comment Share on other sites More sharing options...
