Render node
• Intel Core 2 Quad Processor Q6600 1066MHz 8MB LGA775 EM64T CPU
• INTEL STANDARD PROCESSOR COOLING FAN
• GIGABYTE P35-DS3L MOTHERBOARD
• AENEON AMPO 4GB (2x2GB) DDR-2 667MHZ PC-5400
• Western Digital WD800JD 80GB SATA2 7200rpm 8MB Hard Drive
• IBM 48X CD-ROM DRIVE
• nVidia Ge-Force 8400GS 256MB w/TV-OUT/DVI PCI-Express Video Card
• 6-CHANNEL DIGITAL SOUND ONBOARD
• 10/100/1000 Fast Ethernet Network Card (onboard)
• Rosewill Mid-Tower ATX Case
• OKIA A-POWER 600 WATT ATX POWER SUPPLY
• Microsoft Windows XP Professional 64bit (CD & LICENSE INCLUDED)
Price: $808.00 per system
Looks like a deal, can anyone see any problems with this setup?
get higher clock DDR2 ?
they'r pretty cheap nowadays..
also get rid of the standard cooling fan..
if it's just a node why wouldn't spend any money on a video card? if you are going to work on the machine from time to time though, it's a different story
I have three old systems at home that I have converted into rendernodes, and I've pulled the videocards from them and if I had I would just use the onboard video card. I actually don't even hook a monitor to them, I just use remote desktop and plug them in with only the power and network cables.
You don't need CDROM
Get Better RAM - At least 800mhz. It's very good option for oveckloking. My Render nodes are on the same MB. Very good choice. I clocked the CPU's to 3.2ghz.
Actually you need the videocard, because the MBs with onboard video can't be overclocked.
Good Luck :)
P.S. WinXPx64 - the best choice. VISTA is rotten :)
