jorisAR Posted February 8, 2008 Share Posted February 8, 2008 Hi guys, on this render the hedge in the back is set with a diffuse and opacity map on a plane. When I render you can see a thin line above the hedge, this is the edge of the plane. Am I doing something wrong...or do I have to enlarge the plane, so that the edge isn't visible within the camera viewport...? Link to comment Share on other sites More sharing options...
Horhe Posted February 8, 2008 Share Posted February 8, 2008 Does your plane have a thickness? Or is it straight max one sided plane? If it does have thickness then make it one sided only. Try making the secondary ray bias to 0.001 in the rendering tab. Check if the alpha and diff maps are the same height. Maybe youve got 1 or 2 pixels on higher than the other. Link to comment Share on other sites More sharing options...
scarp8 Posted February 8, 2008 Share Posted February 8, 2008 Paint a line at the bottom of your opacity map. A couple pixels should do it. Then rerender, it should work. Many times your textures are slightly blurred by your 3d program. A couple pixels (or more) on your opacity map edges will get rid of the "line" problem. Link to comment Share on other sites More sharing options...
jorisAR Posted February 8, 2008 Author Share Posted February 8, 2008 Thanks for the replies...the clue about blurring was the one that finally helped. It was to 1. I turend into 0.1 and that helped greetz Link to comment Share on other sites More sharing options...
