Office Entrance
jophus14
Here's a quick update. I brightened up the scene in PS.
After the scene rendered out I was thinking the same thing about how the cladding looks like it bows out in the middle. I'm not sure why that is though. The geometry is just beveled boxes. I will try to switch up the color of the stone to a pale grey and see if that helps.
blowback: I was thinking about doing a dusk version of this image. I think it'll look nice if I get it dramatic enough with the sky and interior lighting.
Hi Joseph Skowron,
I think you're on your way to a final image, the only thing you have to do is the post work. Edit in photoshop, play with contrast, levels, etc and it looks a lot better. I just spend 3minutes in photoshop and this is what i end up with...
(hope you don't mind i edit your image)
Roest: I agree with your post. I spent only 20 seconds in PS playing with Levels and Curves. I'm glad that I re-rendered the image last night though because I realized that the settings were quite low. My render time went from 1.5 hours to 7 hours, but what can you do. I'll play with the image in PS a little more and finish it. Thanks for all of your comments everyone :)
i agreed with an earlier post that the lighting felt a little flat, however Roest's quick play in p'shop has really brought out the image. (not wanting to take anything away from yourself, it just need that little adjustment!)
Overall the image has developed well from your 1st post and you have really taken onboard peoples comments, which is going to show in a very nice final image. I'm sure your client will be very happy!
a comment i would add, but its probably due to the design rarther than your image, is the lack depth to the interior. The facade has a very nice feel to it, but somehow the rear internal wall seems to... "pushing its way right up to the glazing"... is probably the best way i can describe it.
Much better!
if you plan to render again, which isn't really necessary, maybe center the entrance (three double doors) a bit and maybe another aspect ratio?
If you don't render sharpen the image a bit in photoshop and like mentioned above, some people will give some life in there. Imo not to much and a bit desaturated so it don't tracks all the attention.
my 2cents :)
