chow choppe Posted February 15, 2008 Share Posted February 15, 2008 hi all i am stuck with something see attached image i am trying to model a facia of a covered verandah which has arches in elevation and a band /cornice runsa along the bottom profile of the facia I have no idea how this can be modelled in AUTOCAD Thanks Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted February 15, 2008 Share Posted February 15, 2008 You can create the object in plan view extruding it, then creating a solid of the arc, copy/rotate it, and use boolean to subtract from the first solid. Link to comment Share on other sites More sharing options...
chow choppe Posted February 15, 2008 Author Share Posted February 15, 2008 what about the additional band that is running along the bottom like a cornice Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted February 15, 2008 Share Posted February 15, 2008 I'd do 2 separate objects, one for the arc and another for the band (the same way as the arc). Link to comment Share on other sites More sharing options...
ipxstudios Posted February 16, 2008 Share Posted February 16, 2008 trace over the elevation with splines, extrude and slice vertically using the sub object mode - you have to provide enough segments to create a curved surface (or you can just subdivide the whole thing). Then use the bend command to get the radius you want. Link to comment Share on other sites More sharing options...
chow choppe Posted February 16, 2008 Author Share Posted February 16, 2008 looks easy while reading but not easy while actually modelling please help graphically Link to comment Share on other sites More sharing options...
Claudio Branch Posted February 18, 2008 Share Posted February 18, 2008 please help graphically Alright... have you considered modeling the form in Max and then exporting it to an AutoCAD file? I just did a quick generic model of your form using splines with high vertice counts and a Bend modifier. I exported it as a .dwg file... Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted February 18, 2008 Share Posted February 18, 2008 trace over the elevation with splines, extrude and slice vertically using the sub object mode - you have to provide enough segments to create a curved surface (or you can just subdivide the whole thing). Then use the bend command to get the radius you want. He needs it in AutoCAD... Link to comment Share on other sites More sharing options...
Claudio Branch Posted February 18, 2008 Share Posted February 18, 2008 He needs it in AutoCAD... Yes, I believe I noticed that when I mentioned "exporting the file back into AutoCAD" in my response to the post. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted February 18, 2008 Share Posted February 18, 2008 I know you noticed, but I think Julian didn't. Link to comment Share on other sites More sharing options...
Claudio Branch Posted February 18, 2008 Share Posted February 18, 2008 Perhaps I need more sleep, glasses or both! Link to comment Share on other sites More sharing options...
