Devin Johnston Posted February 15, 2008 Share Posted February 15, 2008 I've been noticing that even though I assign render nodes to jobs after they were initially submitted to BB that these machines never start rendering. I'll highlight a job, select "selected job" and see all the nodes that are supposed to be working on that job. Some of them are green but most of them are yellow (idle) and no matter how long they are there they never render. I've tried changing the priority to critical but it doesn’t change. It's almost like if I don't choose these machines at the time I submit the jobs I can't add any more machines to that job. I've never seen this before and it's really becoming a problem. I'm using Max 9 32bit with SP 2, has anyone else had this problem? Link to comment Share on other sites More sharing options...
Claudio Branch Posted February 15, 2008 Share Posted February 15, 2008 We have had that problem (amongst others) and found that restarting the Manager service usually clears up the problem. Link to comment Share on other sites More sharing options...
Devin Johnston Posted February 15, 2008 Author Share Posted February 15, 2008 Thanks Claudio I'll give it a try! Link to comment Share on other sites More sharing options...
Devin Johnston Posted February 15, 2008 Author Share Posted February 15, 2008 That worked Claudio, do you know what it happens? Link to comment Share on other sites More sharing options...
Claudio Branch Posted February 15, 2008 Share Posted February 15, 2008 Devin, we don't really know why it works...I suppose the app just gets hung up and needs a reboot. I am switching over to a render management app called "Deadline" (made by Frantic Films). It is replacing BB and I will use it for "net-meshing" with Real Flow. Link to comment Share on other sites More sharing options...
ihabkal Posted February 15, 2008 Share Posted February 15, 2008 I've had that problem before and updating BB worked for me... Link to comment Share on other sites More sharing options...
Devin Johnston Posted February 19, 2008 Author Share Posted February 19, 2008 Claudio, that Deadline software look to be pretty expensive, do you have it yet? Is it really that much better than BB? Link to comment Share on other sites More sharing options...
Claudio Branch Posted February 19, 2008 Share Posted February 19, 2008 Claudio, that Deadline software look to be pretty expensive, do you have it yet? Is it really that much better than BB? Devin, "that much better" is really relative to your firm's needs, budget and tolerance for bugginess in an app. In all honesty, I can usually tolerate the bugginess of BB. It works well 90% of the time. However, its really only good for Max. Deadline will manage multiple apps and it is a must for the work I do with Real Flow. Deadline and Qube! will both let you try out their software on a 30 day trial basis. Qube! is cheaper than Deadline I believe... Link to comment Share on other sites More sharing options...
