RAM usage?
I have a question about my RAM usage, I have 8 gigs of Ram with XP Pro 64bit. but I did a little test and watched my ram usage as I rendered just a region of my scene, . now the cpu usage shoots up to 100!, and in availible RAM it says I have about 6 gigs left. Am I not reading this right. I am using max 64 as well, I guess what Im asking is is my entire cpu resources being used. just doesnt seem like a little region render would do this
Ain't no expert here, but I believe the amount of RAM you got doesn't interfere on the CPU usage. I mean, we are talking about your processor, so you can use all of your processing power and not all your RAM. Small scenes can take very little RAM to render, but if they have lots of reflections, refractions, displacement, etc, those will eat up your CPU power.
Rendering packages should always use 100% of cpu (processing power) unless you tell it otherwise. It is calculating information as quickly as it can. The RAM is moving that information back and forth to the cpu.
As Rick said, scene complexity, high res material maps, complex lighting, etc will be a deciding factor in RAM consumption. If you do hit you RAM limit things really slow down - or crash - best avoided! Its always goood to have some RAM spare.
Hope this helps.
