Hatem Sayed Posted February 16, 2008 Share Posted February 16, 2008 This is my problem with th eexterior day light nitice the changing in the shading ov the vertical lines i don't know the reason of it and it is happening in each frame of the animation causing bad result. i worked with A&D materials,daylighty mental ray system no AO With High image sampling so what i can do please help Link to comment Share on other sites More sharing options...
Justin Hunt Posted February 17, 2008 Share Posted February 17, 2008 If you are taking of the very thin vertical lines flickering during the animation then increase the min sampling. Also turn in Jitter I agree with brian ints not too clear what the problem is so I am taking a stab in the dark Nice rendering by the way. JHV Link to comment Share on other sites More sharing options...
Hatem Sayed Posted February 17, 2008 Author Share Posted February 17, 2008 Before any thing,thank you Brian and Justin for your help,My problem is that during the animation the front faces of the fertical boxes of the building it seems like it is disappear and appear again from a frame to frame making bad effect afriend of me told me that it is reated with the photon solution whish i am not expert enough with it so what is the best Gi and FG sitting for that scene although i raised the min sampling up to 4,at the end Thank you Link to comment Share on other sites More sharing options...
