Billabong Posted February 16, 2008 Share Posted February 16, 2008 I am having to create a marsh, kind of like what are on inland coastal waterways(image). I created a plane and added a noise modifier to it, that way only certains parts of the plane would stick up above the water, what I can't figure out is how to only apply the hair and fur modifier to just these parts. Is there a tutorial somewhere that might cover something like this. Thanks for any help Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted February 16, 2008 Share Posted February 16, 2008 Not in front of it right now, but I am almost sure there is an option to have it applied by material ID or selected faces... Link to comment Share on other sites More sharing options...
Billabong Posted February 16, 2008 Author Share Posted February 16, 2008 hhmmm, OK, thanks Rick, I didn't see it, ill have a look again.will let you know thanks again Link to comment Share on other sites More sharing options...
Eric Sosa Posted February 16, 2008 Share Posted February 16, 2008 Not in front of it right now, but I am almost sure there is an option to have it applied by material ID or selected faces... i'm shure there is a tutorial specific about it somewhere and it is very good. i did use it some years ago...tho. Link to comment Share on other sites More sharing options...
BrianKitts Posted February 16, 2008 Share Posted February 16, 2008 Quick and easy way would be to just add an edit mesh mod onto your stack, and do a select by polygon, then just marquee select all the faces below the water and delete them. Link to comment Share on other sites More sharing options...
Billabong Posted February 16, 2008 Author Share Posted February 16, 2008 thanks guys Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted February 16, 2008 Share Posted February 16, 2008 Quick and easy way would be to just add an edit mesh mod onto your stack, and do a select by polygon, then just marquee select all the faces below the water and delete them. I wouldn't use edit mesh... I've found Editable Poly works better... anyway, you could just detach the faces you want to use the grass with and apply it only to them, as Brian said. No need to delete anything, though (I believe you want those underwater faces, don't you?) Link to comment Share on other sites More sharing options...
Billabong Posted February 16, 2008 Author Share Posted February 16, 2008 Rick, you are slowly,unknowingly becoming my mentor.(j/K) Thanks so much guys, Im almost to a point where can i start posting wips Link to comment Share on other sites More sharing options...
