nilariver@gmail.com Posted February 17, 2008 Share Posted February 17, 2008 Any body can tell what is vray frame buffer, what is the use of it or where i will get this information. Is max also having frame buffer ? Link to comment Share on other sites More sharing options...
nelpiper Posted February 17, 2008 Share Posted February 17, 2008 the vray framebuffer is the rendering window that shows you (the designer) how the model will be in its final result (bumps apllied, textures, lighting, etc). MAX has a rendering window as well but it's as not nearly powefull and flexible as the vray framebuffer. You can by checking out the vray documentation page. Good luck. http://www.spot3d.com/vray/help/150R1/vfb_index.html Link to comment Share on other sites More sharing options...
